Newbie to the drone world. Just got a Mavic
Pro2.
mavicpilots.com
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
According to Transport Canada, drone use is allowed in Canada, subject to regulations. Read on for more details on the new Canada Drone Laws
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic 2 Pro/Zoom, including the User Manual.
At DJI Download Center, Learn aboutMavic 2
www.dji.com
Happy Droning…
