He’s running iOS on an iPad but the fix still might work.From the Flight log retrieval and analysis guide
"In some cases, for reasons not fully explained but possibly mobile-device hardware related, and most often under Android, DAT files are not created .......”
Thank you. I read somewhere that IOS has to be told to allow access to these dat files, but for the life of me I can’t find it.
Don’t know , but I flew with my iphone xr and same . Did a search for *. dat and nothing ?
Yes many times. So the only try is delete and reload ? Hell I’ll give it a try. Seems odd its the same on phone and ipad.
I would definitely try deleting and then reinstalling the DJI GO 4 app.
Its empty Mini Txt is fineSo the MCDatFlightRecords folder is empty, or doesn't exist? Are the txt logs being created? Which Mavic model is this?
Yes 1.06 only FlyThat seems to be a relatively common issue with the Mini. I haven't seen an explanation or a fix yet. Are you on the latest firmware and app versions, and do you have the DJI GO 4 app on your devices too, or just the Fly app?
Can't say anything about this for GO4 ... but if you own a Mini can you try the theory about syncing to DJI servers deletes the DAT.OK, this is strange for me.
I have owned a number of M2P and for two of them, I could get .DAT file for one but not the other. Both crafts have firmware version 510 and use regular controller + iphone + DJI GO4.
I have sold one of them and today I just found that the flight records in DJI GO4 has got the .DAT file for the sold M2P but none for the M2P in hand. The .txt files are there for both crafts though.
Are there anything I should try to get the .DAT files recorded for the M2P in hand ? Not sure if this is relevant but I have got DJI GO mod app ( base on v24 ) and DJI FLY installed in the same iphone. From iTune, I can see that the files for each app are seperately stored. Futhermore I always make sure that only one DJI app is running and the others are all killed in advance.
