No Headlights
Dgardner007
hello fellow MPPs a quick question, has any experienced no headlights after startup? I've recently have been experiencing this , upon start up sequence all lights come on tail light begins to flash ,rotors twitch, the DJI sound plays, then
my red headlights turn off as the rotors spin up ..... what has happened to my drone.... I've check the setting that deals with that in the camera settings ...LED headlight auto turn off no matter how that is switched ,,,they stay off except
during a countdown they will flash, once the sequence is complete they turn off
again .....WTF
Please help
Sincerely
No headlights
Make sure the lights are turned on in the following section of DJI GO:
You can also set the C1/C2 button to toggle the lights on/off in the following section of DJI GO:
thanks I will give it a try im sure i went to those menu but will try again
Thanks
I followed your directions and and didnt find that selection for my head lights ... I currently using djgo4 version 4.2.14
The only way i can switch them by configuring one of my C buttons
That's correct. If you want to see the other setting, you'll need to run DJI GO on an Apple device.
aquaprinters87
