No Longer Given the Choice of Go4 or Litchi or Airmap on Startup
JAW
Did I Just Back Into That Tree?
Coastal NC to Long Island
After upgrading my Crstalsky as well as the new Fly Safe database, I am not given the choice to choose between Go4, Lichi, or Airmap. My normal procedure has always been a "one time only" choice.
Any help?
TIA
For a standard Android device here are the steps.
  1. Go to Settings.
  2. Locate and tap the App Manager.
  3. Tap the menu button (three vertical dots in the upper right corner)
  4. Tap Reset default apps.
  5. Go through the listing of the apps (Figure B), and tap clear for all the defaultsto be reset.
Thanks, BDOG.
Apparently, the Crystalsky version of android doesn't have the Reset Default Apps feature. Also, no three vertical dots and instead of App Manager, there's just an Apps setting which brings up the running apps (but no dots.)
Previously, it would just load Go4 automatically so I went into settings and stopped the Go4 app, then loaded Litchi which would load but not connect. So I shut down and restarted and Litchi automatically came up AND connected.
Arrrgh
Got it!
Went into settings/apps/ALL/ and cleared the Launch by Default check box for Go4, Litchi, and Airmaps.
Thanks BDOG for putting me on the right track!
testtest
