No video on Android phone / Mavic 2 Zoom
Rich Sugden M.D.
Wilson, WY
Getting used to the Mavic 2 Zoom, and have always used iOS iPhone for my DJI monitor on other drones .. and on the Zoom when I got it ... Today tried an Android (Cubot) phone, and it seems to work fine EXCEPT no video ?? Went back to the iPhone and worked fine ... any suggestions?
Don't know that model phone. I've used the Zoom with a Blackberry Priv (their first Android model) and it worked fine. But then moved to a Samsung Tab A. also worked fine. Try a different cable? Try the bottom usb port (the larger one). Also, be aware, that you can only use ONE port at a time. A cable in the upper, side port will disable the bottom port except you can use the upper port to recharge or power bank while using the bottom port.
Found LOTS of comments about many/most Android phones no longer working after last Firmware update ... iOS OK ... Well aware of port problem ... All of DJI GO 4 seems to work fine except no video ...
rge99
