I'm trying to set up a waypoints mission where the drone has to go over a bush and under an arch. The bush I was probably about a meter above it, and central through the arch. I used the C1 button to set the waypoints precisely and the speed is very low so I can walk behind it and hit cancel if necessary. Then I turn off the obstacle avoidance sensors.
But when I run the mission, it gets to the bush, detects it's there and has a wobble. When it gets to the arch it just stops. It's in P mode, and I did get the warning messages when flying without sensors. Any ideas as to why it still seems to be acting on the sensors?
