- Joined
- Oct 3, 2017
- Messages
- 1,067
- Reactions
- 733
Mavic 2 Pro.Almost new.Never crashed.When drone in air the up/down 90 degrees function is only working occasionally after many pushes of button..The dial for gradual angle adjustment hardly works at all.When drone is on ground and drone on but motors off works fine.In hand or on ground with motors on same erratic behavior.Sometimes get gimbal overload warning.Gimbal protector is off.When you get gimbal to point down with rear switch and try to point staright ahead with that switch it moves a little then stops.Gimbal is set to be able to go up 30 degrees.When drone is off gimbal is movable freely.Any ideas to what might be causing this?
