is there a way to prepare route/waypoints on Android and/or Windows...and fly the route with DJI Go 4?
waypoints 2.0 needs the drone to be powered while creating the route!
Thanks in advance!
Thanks in advance!
from what I have heard, to use Litchi routes...you have to fly litchi, instead of Dji Go 4. Am I wrong?Try Litchi or DJI GS Pro (iPad only)
You can plan the flight in Litchi. Take off and start the flight in Litchi and then switch to DJI go 4is there a way to prepare route/waypoints on Android and/or Windows...and fly the route with DJI Go 4?
Thanks in advance!
and on switching to Go4 , programmed route is kept and executed?You can plan the flight in Litchi. Take off and start the flight in Litchi and then switch to DJI go 4
Yes.and on switching to Go4 , programmed route is kept and executed?
Yes.
A waypoint mission is uploaded to the drone and is held in the Drone’s internal memory for the duration of the mission so you may start up in Litchi, take off, upload the mission, pause the mission, quit Litchi, open DJI Go 4, and the waypoint mission will be show up in DJI Go 4’s waypoint interface where you can resume the mission.
You would certainly need to purchase Litchi for this to work.Interesting, and I will have to give this switching idea a go.
I did read somewhere that you should land the aircraft before switching apps, but don't quote me on this - it's just a memory and might be wrong.
FWIW the Litchi app does work well on both Android and Apple. The PC planning on Litchi is free, but in order to take off and upload the flight path to the drone you are going to be using the Litchi app. Having paid for it, in my view you might as well use it.
I just wish waypoints 2.0 had the same functionality for offline planning as Litchi.
That I am not sure about. It’s possible but I haven’t tried it.Can I now save mission from drone under Go4/waypoints2.0?
I’m somewhat in the same camp as you that you might as well just use Litchi during the mission but there are some onscreen display items I prefer in DJI Go 4 over Litchi such as the map (I find Litchi’s auto zoom function for the map to be finicky) and the attitude radar so I see a function for doing this.
Press PAUSE not stopI tried this out earlier, but must not be doing it right. I didn't have a full battery so couldn't do what I wanted. The spare was dead too - I just jumped on my bike and went to my testing ground.
This was on an ipad mini. I loaded up the litchi flight and hit the play button to take off. Let it start out and hit the stop button and close Litchi. The drone is hovering. Open up GO4, and then open the waypoints. The route I have uploaded via litchi isn't on the screen. Nor is it in the load saved flight.
Obviously you have got it to work, and I'm clearly doing it wrong!
I use Litchi for it's excellent waypoint planning, offline creation and Google Earth simulation....I’m somewhat in the same camp as you that you might as well just use Litchi during the mission but there are some onscreen display items I prefer in DJI Go 4 over Litchi such as the map (I find Litchi’s auto zoom function for the map to be finicky) and the attitude radar so I see a function for doing this.
wrong.from what I have heard, to use Litchi routes...you have to fly litchi, instead of Dji Go 4. Am I wrong?
my Aim is to fly DJI Go4, but with routes created offline.
unfortunately currently no access to iPad but just Android and windows
Why complicate things unnecessarily?from what I have heard, to use Litchi routes...you have to fly litchi, instead of Dji Go 4. Am I wrong?
unfortunately currently no access to iPad but just Android and windows[/
See the answers above. If you perform the things in te right order you can program your flightpath in Litchi and after start hit the pause button and then quit litchi and start the DJI GO 4 app.
