If I buy another Mavic Mini, drone only, can the existing controller be bound to whichever one I'm flying?
yes its the same as if you crashed your drone and received a replacement just go through the pairing sequence for the new droneIf I buy another Mavic Mini, drone only, can the existing controller be bound to whichever one I'm flying?
Thank you. That was quick, now for my Saturday night lounge in the bath.yes its the same as if you crashed your drone and received a replacement just go through the pairing sequence for the new drone
I should also mention that you will only be able to use one remote at a time. Each time you change remotes the other one becomes unbound and will not connect to the MM.If I buy another Mavic Mini, drone only, can the existing controller be bound to whichever one I'm flying?
Thanks for the heads up.As long as the version of the MM is the same as the remote i.e CE to CE and FCC to FCC. I have both types of remote and the FCC remote will not pair with the CE Mavic Mini.
I guessed that. Is the binding process quick?I should also mention that you will only be able to use one remote at a time. Each time you change remotes the other one becomes unbound and will not connect to the MM.
Yes the binding process is quick and simple. Just follow the instructions in the manual.I guessed that. Is the binding process quick?
