Original Mavic 2 Pro Parameters
Kstarestrella
I made changes to my mavic pro 2 parameters. Making it fly faster in Normal mode (Normal +) and I don't like it. However, I don't remember what they are. Can someone help me please. Thank you
It doesn’t reset them when you hit reset? That’s weird did you modify the firmware at all?
I’m pretty sure it’s the same as the Mavic Pro but you may not have all of these
g_config_mode_normal_cfg_lift_exp_mid_point=0.25
g_config_mode_normal_cfg_rc_scale =0.9
g_config_mode_normal_cfg_tilt_atti_rang=25
g_config_mode_normal_cfg_tilt_exp_mid_point=0.25
g_config_mode_normal_cfg_tilt_gyro_range=300
g_config_mode_normal_cfg_tors_exp_mid_point=0.25
g_config_mode_normal_cfg_tors_gyro_range=100
g_config_mode_normal_cfg_vert_acc_down=-5
g_config_mode_normal_cfg_vert_acc_up =6
g_config_mode_normal_cfg_vert_vel_dow=-3
g_config_mode_normal_cfg_vert_vel_up=4
Reactions: Thomas B
Of above normal params - it is worth only changing vert speed up to 6 and speed down to 5. Do not alter angle, change it to 40 in sport mode instead. You need original angle for P and atti modes to maintain optimal battery current at RTH mode and P mode travel, plus, for optical avoidance to work properly.
Reactions: Kstarestrella
ozwaldcore
