Some views of the Hudson between Yonkers, NY and Palisades Park, NJ. I had to the ascend 1000 ft from the river below to get up over the radio tower. NYC in the background.
Thanks, I noticed that after I posted it. I don't use a lot of transition effects but in this video it seemed to work good with the dissolves. The issue was that I made the cut right at the moment when I flew the drone in a different direction. So you are seeing the drone zoom away from the scene it had been locked on. I should have made the transitions shorter or made the cut sooner.Well that brightened up my Monday morning. Good stuff! Now because I'm a video editor by trade, ya got a couple bad dissolves you may want to check. It could be a bad export or a long dissolve that went into the next shot. The 2nd one I saw was at 2:28.
There are actually a bunch more of those after my time mention. Double-check the sequence but I'm guessing that unless you went to the very last frame of each one of those dissolves, it may be an export setting or something downstream of your edits. Sometimes a difference in footage framerate and timeline framerate will cause some weird blending issues when the software is trying to interpret the footage.Thanks, I noticed that after I posted it. I don't use a lot of transition effects but in this video it seemed to work good with the dissolves. The issue was that I made the cut right at the moment when I flew the drone in a different direction. So you are seeing the drone zoom away from the scene it had been locked on. I should have made the transitions shorter or made the cut sooner.
Yeah, I see what you mean. I am using Final Cut and the basic Cross Dissolve. Everything was 29.97fps. I did speed a few of the clips up. But most are at normal speed.There are actually a bunch more of those after my time mention. Double-check the sequence but I'm guessing that unless you went to the very last frame of each one of those dissolves, it may be an export setting or something downstream of your edits. Sometimes a difference in footage framerate and timeline framerate will cause some weird blending issues when the software is trying to interpret the footage.
I FIGURED IT OUT! I was using an adjustment layers for color correction. When I remove the adjustment layer, it is much smoother.There are actually a bunch more of those after my time mention. Double-check the sequence but I'm guessing that unless you went to the very last frame of each one of those dissolves, it may be an export setting or something downstream of your edits. Sometimes a difference in footage framerate and timeline framerate will cause some weird blending issues when the software is trying to interpret the footage.
I use Avid and Premiere Pro and they both have different type of dissolves so as a test if Final Cut has some, try another type of dissolve. I know it sounds weird since you've done this before but sometimes this kinda stuff happens. Also maybe try a different export profile.Yeah, I see what you mean. I am using Final Cut and the basic Cross Dissolve. Everything was 29.97fps. I did speed a few of the clips up. But most are at normal speed.
I exported using the default "YouTube and Facebook" settings.
Good! Now get that re-psoted so we can watch it in all its glory. Again, great work from flying to editing. Actually if the adjustment layer is just for color, why do you need to add dissolves to it? Isn't that just an "invisible" layer on top of V1 with color added to it?I FIGURED IT OUT! I was using an adjustment layers for color correction. When I remove the adjustment layer, it is much smoother.
Unfortunately, when I add a transitions to the adjustment layers, it still doesn't look quite right. But at least I know the source of the issue.
I didn’t know but I googled it. It turns out it is an old factory that got turned into a movie production studio. Now it seems there is some redevelopment taking place to convert it into a theater. File:The Blue Cube Yonkers from Alpine Boat Basin.jpg - Wikimedia CommonsGreat flying!! I really enjoyed watching. What is the light blue cube building shown from 3:29 to 3:48 while you flew between the stacks?
Thanks - interesting article.I didn’t know but I googled it. It turns out it is an old factory that got turned into a movie production studio. Now it seems there is some redevelopment taking place to convert it into a theater. File:The Blue Cube Yonkers from Alpine Boat Basin.jpg - Wikimedia Commons
