Did this get posted before? Sorry, I haven't been on the forum for a few days.
No one said it was a Tello that hit the wing, it was an indoors demo.Seems implausible. Thats a huge hit that crumpled the metal in such an extreme way. The story starts out with a Tello Drone being launched and we know a Tello did not do this.
The pilot of the plane also states that the drone hit the wing "tip". So how is the damage near the area where the wing mounts to the plane fuselage?
Something is not adding up.
Here's the text in the article that accompanies the video. The incident occurred a year ago, May 29, 2018.He never even said he hit a drone. He made a few comments, showed a picture of a damaged wing and that was it. The video implied it but never said it.
Did I already saw that or did you just read my thoughts exactly ?The same memo, over and over again:
Drone hits plane - rarely ever depicted the other way around because that would set footing the manned aircraft was in the wrong.
Ignore detail of altitude of manned aircraft at time of incident.
Damage generally doesn't match what would be expected from a drone strike.
No drone operator.
No evidence.
But it was a drone.
Wonder when all the airspace authorities will stop letting manned craft and respective pilots have the "benefit of doubt" and issue a mandatory altitude of 1000ft? Then actually enforce it?
You would have to come up with a good reason that existing laws and regulations should be changed and then work out how they could be enforced.Wonder when all the airspace authorities will ... issue a mandatory altitude of 1000ft? Then actually enforce it?
Doesnt seem to be a requirement on drone laws but ill bite.You would have to come up with a good reason that existing laws and regulations should be changed and then work out how they could be enforced.
True. With the way drone use is depicted in mainstream media, justifiable reason would be to otherwise expect "imminent death to the next manned aircraft to take to the air."You would have to come up with a good reason that existing laws and regulations should be changed and then work out how they could be enforced.
Now I'm reading your mind! hahaManned Aircraft will be required to have ADS-B starting Jan. 1 which will transmit aircraft coordinates and altitude to ATC nationwide system. If the data shows non-compliance then you can enforce it. Simple
Life is rarely that simple.So manned aircraft don't hit drones. Manned Aircraft will be required to have ADS-B starting Jan. 1 which will transmit aircraft coordinates and altitude to ATC nationwide system. If the data shows non-compliance then you can enforce it. Simple
I could build a program that cross references google earth ground altitudes with GPS data and automatically sends enforcement letters to the the offending pilots when their MSL altitude minus the ground altitude of the gps coordinate dips below 1000. It would send the enforcement letter to the address produced by cross referencing the registration# of the aircraft with the address on file for the registration and I could probably do it in 5 days and cost under $10000.Life is rarely that simple.
ADSB provides altitude MSL data for the benefit of other aircraft.
It's not giving altitude AGL which could vary widely ... eg. Colorado vs Florida.
For enforcement, someone would have to calculate AGL altitude and the FAA would have to have a new group to do this and carry out enforcement actions.
Do you want to pay them to do that?
Post #10 was also suggesting a big change to existing altitude rules to benefit drones.
I can't see that happening.
You are to cheap - use a subscription model ...cost under $10000.
Good idea!!You are to cheap - use a subscription model ...
