Hello. I have just upgraded from Mavic Air to Zoom, and now I am looking into POI V 2.0.
I have not yet tried POI 2 for real (want to understand it first), so here's what I have gathered so far:
POI 2.0 sounds great (and less risky) in that it's sometimes not advisable to fly above a POI. However, POI 2 sounds very similar to the Circle quickshot, and I can't see much advantage or difference between Circle and POI 2.
Is this correct?
Also, the problem with Circle in the past is that drawing it on DJI 4 sometimes leads to misunderstandings about where the real center of the POI is. If you draw around the "long side" of a building, there are bad assumptions when you get to the short sides. This leads to an uneven circle and a bit of choppiness. Is this also the case with POI 2?
Finally, I think I saw that a firmware upgrade allowed for the side sensors to be active during POI 2. This would be huge as I always get nervous around bigger circles. Is this correct as well?
The User Manual was good but not detailed enough ... Any thoughts or assistance on this would be appreciated.
- You can do POI on a Mavic 2 with GPS (the old way) or with POI V2 (the new way)
- If you do POI 2, you don't need to fly on top of the center of the POI to establish the circle
- Instead, with POI 2 you are able to draw around the POI on the DJI Go screen
- From DJI Go, you can establish the direction, speed, etc.
Is this correct?
