I have a MP2 with a 16ND Polarizer filter and having problems using it.
I get it dialed in on the ground facing the direction of the shot that I want and then I adjust the filter so I get the effect of the polarization with blue and green etc. Two problems, I have a hard time being able to adjust the proper setting on the filter using an IPad as my display with DJI GO 4. It is just hard to tell much of a change while making adjustments. What technique has some of you used to get the filter dialed in?
Second, As soon as I turn the drone the effect of the filter changes and sometimes not for the better. I understand how it works and you are going to get different amounts of polarization depending on your direction to the light source. Do all of you just shoot in one very defined direction so that there is no change in the effect of the filter? Any advice on how best to use this filter is appreciated.
Thanks in advance for all replies.
