Dear all,
I want to know if it is possible to land the aircraft on a place and leave the propellors just on?
Thankyou!
Thankyou!
Yes.Dear all,
Thankyou!
Yes you are right. I am scared maybe battery life is not high enough to start again and than my drone is there standing on the ground, i know mavic can give this message when battery is getting low.Are youn asking so you can start up again and keep flying at range?
You can disable that auto landing behavior by disabling the "Landing Protection" setting in DJI GO.I don't think you can do this with the Mavic 2... Pushing the left stick down when you're near the ground initiates 'landing mode' just as if you slid the landing slider. In landing mode, the motors automatically shut down when the landing is complete.
If you lose connection (a real risk with the many obstructions at ground level) you won't be able to take off again if you land.
That's all it seems like it would do based on the description in DJI GO.I'm aware of the function, but I thought it only saved you from landing on an unsuitable surface. (That's all the description under the slider says it does).
