Code:
One tree connects one end of the antenna wire, the other tree connects to the other end of the wire. The feed line is in a third tree. I had been using the same sinker and fishing line on the other flights successfully. The first and second sortes went very well,
The sinker is heavy enough to penetrate foliage and pull the line up other side of the tree. The sinker is light enough to lift with the MM, I'll admit very close to max and on the edge of the performance envelope. Thanks for any input.
Before anyone criticizes and says: "it's no wonder" after looking at the pictures. The only way to see this image, is to do a major inspection by removing to blades and reinstalling loctite, who does that ? Was it unairworthy ? What does the data say ? The leading edge nicks occurred after preflight inspection and during the crash sequence.
73's
