Does somebody know, why the Mavic Air 2 propeller airfoils have a sharp leading and trailing edges, while common theory claims that leading edges should be rounded
Leading edge is normally done for strength of the airfoil, so as DJI has a propulsion engineering section that designs from ESC, Motor to propeller I would have to give a guess that it was done as a resistance to drag and a noise factor...but just guessing There is a lot in play with a airfoil so at some point they gave up on something to gain something...basically that's all I got.Does somebody know, why the Mavic Air 2 propeller airfoils have a sharp leading and trailing edges, while common theory claims that leading edges should be rounded
The question remains: Why have Mavic Air 2 propeller airfoils sharp leading (and trailing) edges?Hiflyer201, thanks for your answer. You are correct that sharp edges prevent the formation of a detached bow shock in front of the airfoil. A bow shock occurs when an object in the air reaches supersonic speeds (above 343 m/s).
A typical drone motor reaches a maximum speed of around 9600 RPM (Hacker Be20 26 L – 2080 KV motor). Teamed up with a rotor blade of 7” in diameter, one gets a tip speed of about 460 km/h. Let’s say the drone reaches a maximum flight speed of 40 mph (MA2), the resulting maximum speed for the rotor tips would be 525 km/h. This is less than half the speed of sound. Ergo: Bow shocks cannot be created by drone typical propellers, therefore sharp edges are not needed.
Why have Mavic Air 2 propeller airfoils sharp leading (and trailing) edges?The question remains: Why have Mavic Air 2 propeller airfoils sharp leading (and trailing) edges?
It would be nice if to go to the hobby store and get some "real" props to modify and try out and see. But, they would not have any, for lack of a better term, counter rotating props....at least as far as I know. I may go and check it out. I know they have tons of them.....but I'm like you, why not go ahead and make complete airfoils? My conclusion is that its easier and cheaper, and could be because it's more responsive....I did it: I modified the airfoil according to textbook knowledge. The drone seems quieter and the batteries last longer - oh well, it might be it is only wishful thinking.
I could answer my initial question experimentally - no more response required. Thanks to all who tried to help
I curious about your method. Did you lightly sand off the sharp leading and trailing edges? If not that, what did you do?I did it: I modified the airfoil according to textbook knowledge. The drone seems quieter and the batteries last longer - oh well, it might be it is only wishful thinking.
I could answer my initial question experimentally - no more response required. Thanks to all who tried to help.
Just sanding would be like guessing, which is not good enough. I employed a modified commercial CFD program and computed for a dozen radial distances of the propeller the optimum leading edge profiles. It turned out that they were of a shape similar to inclined elliptical shapes. Then I produced templates for the profiles and while sanding and checking by templates I interpolated the profiles in between the template locations.I curious about your method. Did you lightly sand off the sharp leading and trailing edges? If not that, what did you do?
You might be right. That is probably the reason why you can get one set of four props for the Air 2 for the bargain price of $ 23.99 from Masterairscrew. Oh, I forgot you get "STEALTH" propellers ... and in colour!I'm guessing for ease of manufacture.
