Hello...
After watching some videos on You Tube, I have seen different points of view about adding protective covers to the top of
each prop motor on the Mavic Mini. In one You Tube video, a person ran his mini stock, then using a gun to measure heat
(the gun shot a light at each mother) he measured the temperature of each motor. He did this indoors, after the mini had
been hovering for 20 minutes.
After this benchmark, he installed some metal prop motor covers and then hovered the mini indoors for another 20 minutes.
He found no change in the motor temperature.
I do want to keep my mini clean and thought about adding them (see enclosed photo).
Do many folks believer it will cause harm in the long run to the prop motors? I am trying to make up my mind and am open to
points of view pro and against.
Thanks so much,
mraroid
Thanks so much,
mraroid
