Question on distance
Bendsum
I have the fcc version and I am only able to get 1/2 mile in rural area before all connections are lost. Is that normal?
Maybe your not aiming just right.
If this app showed you like the Go App WiFi signal bar
the same you could adjust your aim as you needed to.
is what I do dislike about this one it shows full bar but then is just gone. All you see when your off a little is the picture
starting to get pixelated.
Goin to try this out tomorrow. if no improvement the mini is goin back or getting traded off.
It’s a discussion forum. I like discussing things.
You're new to the forum, but I can guarantee that eventually you’ll get bored of seeing the same questions ad nauseam. So, it’s good to encourage people to use the search function. It’s also better for the OP, as the older threads will have been covered comprehensively so it will save them time, and everyone else. ?
SkyTechDji
