Question: Power inverters to use chargers in the car
Example:
Get something like this or this so I can plug in a charging strip like this?
Hi Neal - I actually have the same Tripp Lite cupholder inverter, but it only has a 2 amp and a 1 amp USB port. When plugging in my Mini’s three-battery charger, the dots progressed slowly, thus not fast-charging.
So I ordered this from Amazon, which advertises 6 amp (2 x 3 amp USB ports). When plugging in my charger, I now see the fast lights indicating a rapid charge.
I agree with sar104: a 12 V USB charger is sufficient, without the inverter, and you’ll want to ensure you‘ve got the newer car charger that offers at least a 3 amp USB port.
Another thing you need to pay attention to is not to drain off the battery of your car. This has happened once to me.
The car wou be running. I wouldn't be charging while the car is parked with the engine off. I just want to be able to charge while driving to the next location.
Reactions: pelagic_one
Then just use a car charger.
AFAIK, they do not make a car charger for the Mavic Mini. That's not my point. If I am in my home I can plug something like this into the wall.
I'm just asking can something like that be plugged into one of these?
@pelagic_one - So I can order that and plug the Mini Battery Hub and the RC into the charger and charge those while driving?
The reason why I was wondering about an inverter or plugging in a charging strip like this one is so that I can charge the batteries, RC, a phone or tablet, etc. all at once.
Now I can see that you need a lot of USB ports. Will this do ? It says it support quick charge but I am not sure if it means QC 2.0 quick charge standard or above. Mavic mini use QC 2.0
Reactions: Jun910
testtest
