Questions for you guys in the know.
Sprocket
Missouri, U.S.A
Can someone elaborate on this and explain just how important this data is and when I should change or balance props? It seems kinda generalized to me. Thanks.
Maximum Response Time
One time event
The highest one time event
(lower is better)​
Response Time Per Right or Left - allow you to identify if turning to one direction responds faster than the other. If a strong deviation is observed over multiple flights - it may indicate that the propellers are worn out or need to be balanced. Flight characteristics and weather may affect these values. Note: fewer turn records will provide less accurate information.
Left turn
Avg. response time
0.294 seconds
Using 34 turn records
-11.6
Right turn
Avg. response time
0.260 seconds
Using 35 turn records​
Right turns respond faster by 0.034 -11.6% seconds
POWER
One time event
(lower is better)​
Left turn
Avg. response time
0.294 seconds
-11.6
Right turn
Avg. response time
0.260 seconds
POWER
You can't do anything to balance the props, I honestly don't read too much into this on Airdata but changing the props is only needed if you see wear on the blades or if they are not securing into place. I used the same props for over a year. *Edit most of the time the data is incorrect because of wind speed. I don't know how they calculate the data but I do know that if I have wind, it always shows my response times high but to clear it up, I will have Airdata on one of my live streams to explain.
booknehamari
