Hi Folks,
I have a Mini SE and have been using quickshots so it has worked before. Last night I tried to do "Circle" around a person to get some video using the "Circle" quickshot and it did not work. I hightlighted the individual with the green box and hit the start button. It counted down, 3....2....1, etc but then never executed the routine. I assumed it was because there was not enough light. However, this morning I did the exact same thing in daylight and it also failed to perform. It did the count down, but failed to execute the circle. I also tried rocket... same result.... count down but then fails to execute the action.... Any thoughts? I'm using a Mini SE, no payload, exactly configured as before when it did work. Full charge on the drone, the controller and the iPhone.... I'm stumped.....
