Rapid Battery Charger for MM Compatible with MM2 ?
crash3x
Long Beach - New York
Hi, does anyone know if the quick charger I bought off Amazon for my MM will work for the MM2 I just bought? I don't want to fry the batteries :-/
I'm not the best on volts and compatibility etc. From what I understand they are different types of batteries for the MM and the MM2? But I've also heard and watched a few vids of ppl using MM batteries in the MM2 with no issues.
So can anyone confirm if using the rapid changer noted in my pic/link will be safe to use? Thanks!!
Simply if it doesn't say Mavic Mini 2 it is not compatible and I wouldn't try it. Two different battery chemistries and voltage levels. Use in one or the other mini's isn't the same as charging.
I use a Samsung adaptive charger that charge @ apx 15W, the one that came with my S10e. A complete charge in an hour going from 20%.
Marcc
