Registration of litchi
atis
Guts his what questions do they ask you in the registration of litchi as i am just about to purchase it
They don’t, you just pay for it through your apple or google account
Thanks for your reply but i did read on download page the first time you activated you must register with the dji server
Yeah first time you use the app you connect your phone to the internet and launch litchi and it registers with the DJI, this is because it uses the DJI SDK so needs validating as a DJI app. Once done never needs doing unless you uninstall then reinstall the app
Ok thanks for reply oh i was a little bit skeptical as I thought they would be asking for serial numbers of drones, and i would not know where to find that thanks anyway
I’d like to just add that since the Litchi uses DJI SDK you must ensure that when you fly with Litchi that you have killed the DJIGO4 first.
1. For IOS Double tap the home button and swipe up tp close the opposing app.
2. For ANDROID go to SETTINGS - APPS - double tap the opposing app and touch FORCE STOP
It seems that because Litchi uses the DJI SDK, it may cause problems. Litchi tells you this in their documentation.
Happy Flying
Reactions: Exphantomflyer
Happy Flying
I would also add that some devices don’t like having Litchi and DJI go installed at the same time
I may be mistaken, but installed at same time may not be the problem. Being active in background seems to be the issue.
Hi take out the battery you will see them
Read the small print, the Samsung S5 and the sony experia from memory suffered the issue
Happy Flying
Thanks I really appreciate your reply
kmikebennett
