- Joined
- Jul 22, 2018
- Messages
- 133
- Reactions
- 45
Can I change the battery in the remote for the DJI mavic 2 zoom remote? It charges to 98% and when I get out in the field the remote comes down real low in percentage.
No, you can't change out the controller battery. I've seen the charging only to 98% sometimes, but then other times, it charges all the way to 100%. I don't know why the variability. As for your controller draining quickly, you must make sure the device that you're using to fly with (phone, tablet) is fully charged when you fly because the controller charges that device when you're flying. With android devices, you can't shut that off. With Apple, you can. My solution is to attach a small external battery to the controller during flight. This requires that you connect the controller to the phone or tablet with the full sized USB connector at the bottom of the controller, and you must wait until after you make the connection with the drone (via the USB port at the bottom of the controller) before plugging in the battery. Using this method I have about 75% controller battery remaining after 6 batteries.Can I change the battery in the remote for the DJI mavic 2 zoom remote? It charges to 98% and when I get out in the field the remote comes down real low in percentage.
