Remote won't start
Arthur974
Réunion
I receive my remote yesterday because the last one was broken and now with the new one when I try to power on it she's show connecting and it powered off help
And you do the double push? First push once and then hold the second push so it starts up with the raising beeps .
Did you charge it?
You will also need to link it to the drone if you haven’t already.
From what I can understand it seems you need to link the remote to the drone. If you haven’t that is your problem.
maybe it's my usb alimentation block is too powerfull (i use my huawei 18w quick charger) for the remote and maybe some compenent death
Now we are getting somewhere. Fast chargers can kill things. The fast charging works by supplying twice the standard voltage.
If that’s the case it might be the last controller you killed the same way.
I made the mistake with Bluetooth headphones. Cooked.
mgarwood
