My Mavic Pro suffered an crash out of a tree and into some soft mud. The camera broke loose of the gimbal and there was some mud that needed to be cleaned out. I replaced the broken gimbal mount and re attached the gimbal arm/camera. The result is an error about the gimal motor being overloaded and that maybe I left the plastic holder still behind the gimbal.
What I noticed was that when trying to calibrate the camera could look left and right but never so much as a flicker of up and down movement from the control arm. The camera still seems to work fine but since there is something wrong with the control arm, the camera "freaks out" every 45 secs or so as if trying to recalibrate, however it seemed to fly just fine despite all this.
My question is about replacement parts. I've seen just the control arm for sale, I've seen the control arm with the camera, and I've seen the whole gimbal set up including the logic board. After watching a few repair videos the install looks possible but very tedious.
Should I chance that the logic board is in tact and just replace the gimbal arm (cost about $55 dollars)
Or is it worth is to shell out another 200 bucks for the whole camera and gimbal set up?
Any thoughts are appreciated as this is my first attempt at working on my drone.
