Replace Polarisation filter on Mavic air 2
LukiDrone
Switzerland
Maybe this help someone, I'd struggle to get some info when I try to place the filters for the first time
just hold the camera securely and rotate the small frame to the left a few degrees. counterclockwise. When you look at the filter you will see the tiny feet at each corner. that is all that holds the filter to the lens and it clicks into place. you must remove the empty frame that is in front of the lens first.
Reactions: LukiDrone
da4o98
