Resetting gimbal in flight
macfawlty
Washington, DC
I ran a low flight along a river last week. There were some small gauge power lines in a couple spots. In an attempt to avoid one, think I ascended into it. I may have been stuck on it for a moment and the camera/gimbal got out of alignment, which made my return to home point challenging with the camera pointing sideways. I reverted to my orientation arrow and got back ok.
Is there any way to reset the gimbal in-flight?
With the smart controller, you can hit the 4 way button to look all the way down, then hit it again to look up, that re-centers the gimbal. This is necessary if you use your finger to yaw the camera instead of sticks.
There is a similar process with regular controller, but I am not sure of the buttons, as I have stopped using it for so long.
Paul C
Reactions: johnmeyer
The default is the C1 button on the rear of the regular controller unless assigned to some other feature.
Paul C
Same for the regular controller.
D. L. Hauge
