This is a link to my most recent anomaly involving a similar event in which I completely lost signal and didn't regain signal until I drove to the crash site. In doing so, I feel I was able to collect additional GPS information which revealed the actual crash site was about 100 yards on a RTH vector. As you may notice in the flight data provided
HERE, the last Known GPS coordinate is not the same as where the flight path stopped on the Airdata map. I feel driving to the crash site while the drone still had power, was key, but not positive.
Another anomaly in my crash data is the name associated with my drone. The name indicated at the time of crash was not the name of my drone. How it got changed is a complete mystery. My only guess is from a firmware update.
At any rate, assuming it lost power at last GPS coordinate, then someone may be able to calculate the point of impact using the following:
Last Know position: 42.534822N -76.683178W.
mass: 1.7 pounds,
Forward velocity: 27 MPH
Trajectory: approximately 260 degrees (this is assumed that the map view is North-Up)
quartering tail wind: 140 degree (quartering tailwind is assumed based on North-Up)
Wind speed:.6 mph
Its a long shot since the lights went out at almost 1300 feet AGL., but I'm guessing its in the trees just below the last known position. Why the lights went out is a mystery without video from the drone.
Assuming it is in the tree, I just went through that in the crash listed above, and I have to say, a Mavic blends in very well with the Fall leaves; making it all but impossible to locate. It ended up 90 feet up in a tree I wasn't about to climb. So I simply went to walmart, bought a slingshot, some 20 pound test line, and large fishing weights with a wire eyelet to fasten the fishing line. After several hours searching, I finally located the drone hanging like a bat. It took about twenty shots with the slingshot before I was able to cast it over the right branch. After some vigorous shaking it came tumbling down and is flying today. I do wish I had staged my two teenagers at the bottom with a blanket to catch it, but it was "too cold out" LOL
hope something in this helps
