Samsung S series
you can check here...
but you are probably asking for people that personally use the particular device.
Code:
https://www.phantomhelp.com/tips/best-tabletsphones-for-dji-go.18
Code:
I am not asking about a tablet, I am asking about a phone.
Thank you Oman
I have an S6 Active, S9 and S21 Ultra that work fine. Also, a couple Samsung tablets. The main thing is 64 bit.
My S20 works great for me
What Samsung series S phone can I use with Dji A2S with success ?
Thank you oman
Been doing perfectly fine with my S22 (1.7 thru 1.8 tested), can also confirm the S10, S21 Plus, S20, Z Fold 3, and S21 FE worked fine. On the A series, the A71 worked just fine as well.
Tablet wise, The S7+, A7, and Tab Active3 work just fine as well. (S7+ is nice and big, but it's at best around 300 nit brightness, the S22 and similar can hit over 1,000, the Active3 has a high brightness mode to around 750nit).
Basically if it has 3GB ram or more, and is a 64-bit processor, it tends to be good.
Thank You! Will go ahead and install.
valter123
