I set up to fly tonight and the map function on the ipad display did not show the typical satellite map view even after using the side bars to try to change the display. All I could get was a green background with the orientation arrow which I noticed was not accurate. It was off by at least 170 degrees. Can I expect that recalibration of the axis will fix the orientation issue? What about the map view. Is this an intermittent problem?
