No that screw is completely in tact.Rotate the arm closed, you'll see a screw on the top of the arm joint that was previously hidden by the body shell.
Has this pushed through or been damaged ?
These screws (top and bottom) hold the motor arm onto the body joint
No that screw is completely in tact. View attachment 109788
I took the arm off and the screw came out of the black bracket that holds the arm in place. I replaced the screw and will test fly after work. Hoping everything goes smoothly. Thanks for your help.I'd take off the arm and see if it's one of the screws holding the joint to the body.
See the third pic I previously posted
