Second flight, gimbal overload
ElkySS
Oklahoma
I did my second flight with my new MA2. About 20 minutes in I got an error saying gimbal overload. I've never had a drone like this and never a dji so I was unfamiliar with this. After some research I'm a bit concerned. Should I go ahead and buy that care refresh thing? Honestly, I don't think I should have to use that after only two flights. I guess I'm looking for advice as I'm new. Everything looks tight around the gimbal area. I haven't crashed it. It was hot outside (actual 95F, real feel 99F) but I'm not sure if that has anything to do with it. I looked it over and don't see any dirt or anything that would prevent the gimbal from moving. Anything else I need to check? Or am I worried about nothing?
Reactions: E90RAW
DJI drones come with a 1 year warranty that covers any manufacturing defects, so if your gimbal continues to give you problems you can contact DJI for a free repair.
Care Refresh is more for covering crashes.
I got a flight in today. Used nearly the full battery and never saw that error again. On today's flight I wasn't messing with the gimbal much. I was about 200ft up the whole time. The flight where I saw that error I was playing with the dogs and filming them. I was only about 5 feet off the ground. So I was moving the gimbal up and down a lot following dogs. Could the outside temp plus me moving it around have caused its motor to heat up and pop that error?
[/QUOTE]
it shouldnt
Reactions: itsneedtokno
I'm in Florida and use Active Track at about 10' high to chase my son around the park all the time and have never received a gimbal warning. So I would say no to the temp causing the error.
J S
