This is something that I have posted about in the past with both the P4 series and the Mavic 2 - both of which I own - but it is particularity applicable to the Mavic Air 2 IMO.
The MA2 battery retention clips are now metal which allows for them to make contact with metal plates within the battery bay for the purposes of useful feedback if the battery is not fully and properly installed. This is all very nice, but take a close look at the flanges that these metal battery clips hook beneath. They are made of plastic, and they are fairly thin. If you place the battery into the battery bay and then simply press it inward until it makes that clicking sound, you will very likely wear down the plastic flanges over time, and since this is not plastic against plastic as it is with the P4 and M2 series copters - but rather metal against plastic - this wear will occur fairly quickly.
IMO, the safest method of installing a battery into the MA2 is to place it gently into the bay until it sits properly aligned upon the retention clips, and then press the retention clips inward with the removal tabs followed by gently pressing the battery straight downward until it is fully seated. This avoids the metal clips 'snapping' over the plastic flanges, and will not wear them down over time.
