- Joined
- Aug 2, 2018
- Messages
- 61
- Reactions
- 18
- Age
- 56
What can be used as a shield from magnetic interference? If one were taking off from a car hood for example, what could be put down between the drone and hood to reduce?
A sheet of ferromagnetic metal should do the trick. You'd have to experiment with the thickness to see what would work. See more details here.What can be used as a shield from magnetic interference? If one were taking off from a car hood for example, what could be put down between the drone and hood to reduce?
Or just launch the drone from 8-10 feet from the vehicle.A sheet of ferromagnetic metal should do the trick. You'd have to experiment with the thickness to see what would work. See more details here.
It would be much easier to hand launch or launch from the ground using a landing pad (like one of these).
