Chris, thanks for starting this thread. Believe it or not I've been thinking there should be an HLG thread on the
Mavic 2 Pro forum. I have experience shooting HDR with ProRes Raw and editing with FCPX; this is for showing directly on a HDR TV in Rec 2020. Recently I decided to try HDR with the
Mavic 2, and first tried D-Log to simulate the ProRes Raw workflow - which turned out to not work well; D-Log doesn't cover the bt.2020 range well. Then I tried HLG, and got very good results. After you've seen your drone video on a large HDR screen you'll never want anything else!
But shooting HDR and HLG is new territory, and a thread on this topic for those interested could be very useful.
First, if you just load HLG clips from the
Mavic 2 Pro on a portable drive and plug this into an HDR TV, the clips play fine. Select mp4 format when you shoot, not mov, since TVs tend to recognize Windows formats, not Mac.
The clips can be edited in FCPX. Set up the Library for Wide Gamut HDR, and the Project for HLG. After editing export with Compressor in 10 bit HEVC. The format extension will be m4v, and just change the extension to mp4 and it will play on a HDR TV.
Although they both cover Rec.2020, HDR10 and HLG are very different formats, and can't normally be edited on the same timeline. FCPX has a way to do this, using HLG "Compound" clips, which is useful for anyone that shoots in both HDR and HLG.
I expect the editing can be done in Premiere Pro and Davinci Resolve as well, but I don't have any HDR experience with these. But I'd be happy to tackle any FCPX questions about displaying directly on an HDR TV.
