Yep, I have a great tip for you. But before that,
Story:
(All Flights discussed below are from the same point and in the same neighborhood and in the same direction)
1. With my
MA1, I would at times fly to about 1.6km away, and other times I would only get about 500m before the AC loses signal and initiates RTH
2. With my
MA2, I usually get 3.5km from this point, and yesterday I only got 800m before the AC lost RC connection and initiated RTH.
Here is where to look:
Go into the DJI Fly App and under Transmission, take some time and observe what happens under Channel Mode. By default it should be Auto. The data inside the horizontal range (represented by the white lines inside the graph) represents the channel chosen automatically by your RC-AC. If the graph inside the horizontal range seems to be fluctuating too much, and if you find some part else inside the main plot to be less fluctuating, switch to Manual mode and choose that section of the graph that has least fluctuation (usually also has a larger negative decibel value to it). This should greatly improve the quality of connection between your RC and AC. Although Auto USUALLY does a great job, it occasionally picks poor channels. If the entire plot seems to be wildly fluctuating, go ahead and turn off the AC and RC and try reconnecting to see if the plot seems somewhat better. If not, then you are likely in a bad place and might have to consider moving to a better place that allows a stable connection. If the connection is still poor in an isolated area, you might want to consider getting in touch with DJI.
But from my experience, just switching to the right channel helps.
Also, put your phone in airplane mode before you fly, to remove direct interference from your mobile device.
