Should Calibration notice disappear
Brian Smirke
Hi guy's, just wondering if you can advise. I have a Mavic 2 pro, after installing the latest update, I don't seem to be able to get the drone to calibrate. Have done the whole 360 horizontal and vertical, but the message still says the drone needs to be calibrated. Any idea what I could try??
Cheers
I suppose you have to repeat it, may be some meters away from the point you did it the first time.
Thanks for your response.
We have tried to do it a few times, then decided just to try to fly it. It did come back to home but the message did not disappear from the screen prior to take off. Is this a normal thing?
Is there a way to know that it is callibrated or could this just be a glitch?
When calibrated the notice should disappear. I only can imagine that you have to retry it at another location.
Check the sensor status in the advanced flight controller settings.
You might indeed need to move to another location if this one is magnetically disturbed.
Message should disappear. Try to reboot everything as a first step and see if it comes back, if yes then a good calibration is really needed.
PixelHover
