Should I replace this prop?
sagar_dji
United Arab Emirates
I just got my MA2 from repair after a crash. I see a little cut on one of the props (pics attached) Can I continue using that one or should I replace it?
Reactions: Steel63
Absolutely.
Replace the prop.
Here's my spare prop case...:D
Haven't had to use it yet. :)
any prop damage ,has the potential to cause a catastrophic failure when the drone is flying ,if you value your drone dont fly with damaged props
It's not common for that to happen to the leading edge. I wonder what caused it. I might sand it out in the field if I didn't have a spare but I always have spares.
Reactions: itsneedtokno
Let's see: $10 prop. $1,000 drone. Is this really a question? Now you have an excuse for Master Airscrew props.
refrigasketscanada
