Should I upgrade from .400?
jmfixitman
I am still on .400 firmware and have no real problems that I know of... I stayed on it because of litchi when they were having problems. Do you guys recommend updating or does that screw me into some kind of dji hell?
I have been leary of updating as many folks seem to then have problems with restrictions, etc...
400 won't work with the DJI Goggles, but apart from that I found no problems with it.
It works perfectly fine. My Goggles FW is 0700. IOS Go 4 is v 4.07
The Goggles were designed to work with the Mavic since it’s release. The Mavic Pro is best for me with the 0400 FW. I wouldn’t change a thing because of it being so stable and with reliability.
Many will agree with me on this.
With all of the DJI monitoring, limiting, continuous logins...etc, I'm glad I stopped at 0.700. It works flawlessly. None of the minimalistic newer features have moved me to reconsider.
Reactions: Drone Master
Thanks for the correction. My recollection was that it did not support the full functionality of the goggles, but I guess I was mistaken. It certainly is a stable firmware version.
FW 0700 was good as well, but many had issues with the gimbal and it’s errors due to the FW. With that said, I still feel that FW 0400 will always be the best for my Mavics.
I am still on .400 firmware and have no real problems that I know of... I stayed on it because of litchi when they were having problems. Do you guys recommend updating or does that screw me into some kind of dji ****?
Stay on that FW! Trust me! 0400 is perfect for the Mavic.
Reactions: jmfixitman
I stopped at .700 and DJI GO4.0.8. Use goggles and flies great!
Unfortunately, I'm starting to lose functionality with Autopilot and Hangar360 apps as I accidentally upgraded to latest.
Reactions: JMF
I have not upgraded any of my apps for months since the DJI NFZ debacle.
Still using Litchi. And it works as it should.
I know many are kicking themselves in the ars becuase they upgraded their apps along with Go 4 to the latest.
There are ways to downgrade the DJI go 4 app..... I had the latest and down graded to 4.0.6 that way I dont have to log in.
Im still on .700 and plan on staying there. Whats the difference between .400 and .700?
I think you have airplane flight mode on 700?
I tried it once and didn't like it, still on 400 here, with recompiled app that doesn't contact DJI at all.
Reactions: digdat0
so what version of litchi are you using?
and does anyone actually know if litchi's latest android version will be ok with .400 mavic firmware
PorkoRosso
