Simply i would not recommend it as it only gives cons.
Lipo vs lithium-ion
Watch a video on YouTube which will explain the difference between the two.
Cons of using MM1 batteries in MM2
1. Less flight time due to more weight
2. Premature motorware due to more RPM caused by weight
3. Less power to fight wind as the batteries discharge rate is slowed
4. Less distance
5. Possibly more uncontrolled gimble movements when in sport mode/normal mode due to less power to distribute
6. Requires you to register your drone
7. Drone operator license
I find these findings to contribute to the topic of why it's not worth flying the MM2 with MM1 batteries. If you have MM1 batteries kicking around don't be afraid to use them just keep in mind these facts
Lipo vs lithium-ion
4. Less distance
