Get more from your Mavic
The largest Mavic community in the world
SILENCE YOUR RC WITH SOFTWARE.
mrreddog
yes, it takes less than 20 seconds to flash, and the sound at startup and shutdown are the only sounds it makes. Nothing on low Battery, nothing on RTH
Reactions: CarlStarke
UAVNV
Be sure to use
glasswire and check any exe files before running them [emoji41]
pcath
I have tested it with perfect results!
Everything went smoothly and sounds are all gone.
(I donated to remove the word shareware as well)
Hi , I'm french fly boy!
When you connect you rc on computer, it detected by Windows ?
lenabanana
Windows 7 don't detect my rc , i must find dji driver :
Help - Mavic Air RC Windows driver required
Have you WIN 10 ?
Yes, I used Windows 10.
I believe this is for Mavic PRO. I cannot confirm if it works with Mavic AIR.
If you have a PRO, do you have DJI Assistant installed? Does it detect your remote?
If not, download DJI Assistant first and see if your remote will connect
Reactions: pcath
pcath
I updated my windows (10), but impossible to load Silencio..... error Framework ....
lenabanana
Make sure you run all Windows updates, that is a Windows issue.
There is a tool here that fixes some of the frequent issues but I recommend you check update center in Windows 10 and run all updates. A fresh Win10 install will be missing all the updates from the last year or so.
Here is a link to JUST the framework install
Install the .NET Framework on Windows 10
Use this tool if you still have issues AFTER all Windows updates are installed and you have restarted your computer.
Download Microsoft .NET Framework Repair Tool from Official Microsoft Download Center
mrreddog
I do not know who the creator of the program is??, I ran across this on the Slack group and wanted to share it here. yes, that is your video Amalia, I hope its ok that I used it here. Im just trying to spread the news to the masses..
Reactions: amalia saputro
amalia saputro
No problem mate...
1. Mini SE - $299
2. Mini 2 - $449
3. Air 2 (renewed) - $649
4. Air 2s - $999
5. FPV Combo - $1299
6. Mavic 2 Zoom - $1349
7. Mavic 2 Pro - $1499
vietpantado
