Does it play back in slow motion though? A video recorded in 120 FPS but played back at 30 FPS is 4x slow motion. That’s how slow motion works.I set the 120 fps for recording. When I check the created mp4 file properties, it shows frame rate: 30 fps. ?! (However, it works with 60 fps) Thanks for any help.
So it doesn’t play back in slow motion is that what you are saying?I did try the playback. The recording is definitely not 120fps.
Correct.You mean that recordings with 120fps appears in the file properties as 30fps? Weird!
I understand. Thank you for your effort!Correct.
If you select 120fps, it encodes the final video at 30fps. And you can confirm. Take a 10second video at 120fps. Download it and insert it into your video editor. You will see the video length is 40seconds. (1/4 actual speed)
And no idea why they opted to output 120fps this way and 60fps the other way. sorry.
