While flying the Air 2S with Smart Controller over a flat field at about 8 m, the controller indicated a height of minus 4.3 m. What should I change to get the correct height?
You could land and then take off again. That would reset the altimeter so that it would read 0 at your landing point.While flying the Air 2S with Smart Controller over a flat field at about 8 m, the controller indicated a height of minus 4.3 m. What should I change to get the correct height?
The aircraft sensors do not measure the current altitude location. They measure base in the take-off location.While flying the Air 2S with Smart Controller over a flat field at about 8 m, the controller indicated a height of minus 4.3 m. What should I change to get the correct height?
I used to live in South Florida, and when someone in your area says a field is flat, I believe it.Thanks for your response. I was flying over a FLAT field when I noticed the negative numbers. I was practicing flying tighter and tighter orbits and figure 8s.
I can't think of any reason why those patterns should cause the incorrect numbers.
On the next flight, I'll check the numbers at a higher altitude. My biggest concern is that a RTH might get the wrong data.
I did notice that when I changed batteries the numbers were correct for a little while.
Did you take off from a hill and go down into a valley or take off from your car roof or ???While flying the Air 2S with Smart Controller over a flat field at about 8 m, the controller indicated a height of minus 4.3 m. What should I change to get the correct height?
The indicated altitude comes from a sensor that measures small changes in air pressure.Thanks for your response. I was flying over a FLAT field when I noticed the negative numbers. I was practicing flying tighter and tighter orbits and figure 8s.
The altitude will be reset each time the drone is powered off and on again.On the next flight, I'll check the numbers at a higher altitude. My biggest concern is that a RTH might get the wrong data.
