- Joined
- Sep 30, 2018
- Messages
- 212
- Reactions
- 110
Hi,
I am looking for a software which stitches automatically a pure 2 dimensional map image from about 300 top down aerial images (with GPS coordinates).
The trouble I ran into with the likes of PrecisionMapper, Drone Deploy, MapsMadeEasy and so on, is that they all try to create a 3D image and than safe a 2D representation thereof as georeferenced tif.
As I do not take angular shots (I only need a 2D map) my shots are all top down.
So when the 3D model is calculated first I get ugly edges around objects with a large vertical edge. This happens when the software tries to blend between the different vertical points.
This is also the reason why the trees look ugly from above. See attached image below.
Now, if the program would instead just align (and correct) the images on the same plane I could get rid of this.
Anyone knows of a low cost solution to this?
Thanks!
Thanks!
