Sold
Dogpilot
Flagstaff, Arizona
I purchased this equipment for use during a specific, project. It saw light use during that time and is in mint shape. The equipment was kept in a Nanuk case was instrumental in maintaining this equipment in tip-top shape and avoiding any damage during handling and transport. If you need a RTK unit, don't let this one pass you by. It has everything.
Done with the now, so it is time to let it go to another pilot AT A GREAT VALUE PRICE:
D-RTK 2 High Precision GNSS Mobile Station (D-RTK 2 Mobile Station) is DJI’s upgraded high-precision GNSS receiver that supports all major global satellite navigation systems, providing real-time differential corrections that generate centimetre-level positioning data for improved relative accuracy.
Includes:
D-RTK 2 High Precision GNSS Mobile Station Tripod
D-RTK-2 Carbon fibre Pole
TWO WB37 Batteries and dual charging tray - both charge fully and maintain charge well.
Includes custom foam inserts for Nanuk 985 case (Nanuk case not included)
AC Adaptor for charger
DJI 12V power adaptor to power unit from 12V systems (allows unit to be placed and run for days)
DJI adaptor cable for the 12V adaptor to the D-RTK-2
Carry case for the tripod
Will be shipped as two packages, as the tripod and equipment are not compatible for shipping in the same box. $2,095 + Shipping I take PayPal. You can pick it up in Flagstaff as well.dr1.jpgdr2.jpgdr3.jpgdr4.jpgdr8.jpgdr10.jpg
Reactions: Wing5
The RTK features are not brand dependent. Now I have not tried it with others. You can get others, like Emlid, to work with the DJI. They all broadcast their signals on the same frequency, it is not like the casting is limited to a single drone/caster pair. I do not know how you select the casting unit on the Autel. On DJI it is quite straight forward. The difficulty may lie in selecting which NTRIP/CORS network, which is done via the RC Pro controller for Enterprise. Personally I used it in stand alone over a known survey point, which come to think of it, I entered in through the RC Pro. It may be a better question posed with the Autel professional users group.
Good idea. I just did so, awaiting a reply. I hope that they are comatable as I would like to get into this part of the industry. I own several DJI UAV's but none of them are RTK compatible.
I'll check back with you as soon as I hear something one way or the other.
Thanks!
Rob Cyclist
