Solved: What voltage to Bench Test Mavic Pro motors? ANSWER You need an ESC
kartane
Australia
What voltage do I need to bench test a Mavic Pro motor? Are Platinum batteries the same? I have a drowned MPP and I would like to know if the motors still work.
Do I have to desolder them from the circuit board? I could not find the motor specs anywhere. Yes, I am aware they are variable speed. I just want to put 2 wires across a motor and see it work.
Thanks for looking.
Really, so the circuitry must include a transformer.
No - see my clarification above. I realized after posting that it looked like I was implying an A.C. motor. It's a 3-phase DC brushless but you can't just feed it a simple D.C. voltage.
That makes sense. It needs to be variable.
Thanks for looking.
For testing brushless motors there are corresponding devices from the RC sector. For example, you need such a device:
SkyRC BMA-01 Brushless Motor Analyzer / Tester
But why do you want to test a single motor, is it a spare part? You can also do a simple test directly at the MPP. Start the engines without mounted propellers, and do a listening test. If all four motors are running and sound the same, then it can be assumed that they are working properly ...
Reactions: Former Member
The motors use a 3-phase alternating current, into 3 sets of coil windings ... Have a look at the attached to get an idea of how this works.
roartiz
