I’m about to fit a Mavic Air 2 with some Firehouse lighting, mostly to maintain VLOS. It occurs to me that a flashing strobe could show up in any photos that are taken. Is this an issue??
Two things to consider:I’m about to fit a Mavic Air 2 with some Firehouse lighting, mostly to maintain VLOS. It occurs to me that a flashing strobe could show up in any photos that are taken. Is this an issue??
When you are shooting with the drone, how close is your subject?
What is the effective range of the strobe? (You have to pay big $$ for a photographic strobe that's useful at 10 metres).
Perhaps you didn't understand my reply.perhaps you misunderstood my question. I’m not looking to use the strobe to illuminate a subject. The effective range is 3-miles and of course, I’ll be at a good distance from any subject. My worry is that the light leak will occasionally show up on photos.
Only if you are close to a solid surface... like the ground. Otherwise I have never seen any effect in images or video from ARC2s or ARC XLs mourned in @Aerial-Pixel mounts on legs, LG, or arms of my drones unless I was in dense fog... even at dusk... example below... check the landing.I’m about to fit a Mavic Air 2 with some Firehouse lighting, mostly to maintain VLOS. It occurs to me that a flashing strobe could show up in any photos that are taken. Is this an issue??
Relative to the drone in which direction do you wish to mount the strobes to point?
From memory at least one of my drones offers the option to automatically switch off the forward facing LEDs whilst the camera is recording and possibly whilst taking photos too, so the must be some concern about stray light or reflections.
So why do the front light switch off in the menu of my m2p so that the don’t cast a glow when the camera is used.Perhaps you didn't understand my reply.
You need a huge and very expensive strobe to light photos at only 10 metres.
The strobes people put on their drones are tiny and low powered.
How far away from your photo subjects is the camera going to be?
It's unlikely to have any effect unless you are only a few metres away and very few drone photos are shot like that.
Depends on proximity.., see my vids above.So why do the front light switch off in the menu of my m2p so that the don’t cast a glow when the camera is used.
I wondered exactly the same thing, 2 bright flashing lights next to the camera I would have thought would show up in filming or picture taking. If they don’t is it because they are white not red ? Or is the no point in having the front red lights go off when the camera is running ?
I will check it out when I’m on WiFi at home. Not even full 3G where I am at the momentDepends on proximity.., see my vids above.
If some of the light is directed toward the lens, you can expect to see some glow.So why do the front light switch off in the menu of my m2p so that the don’t cast a glow when the camera is used.
It's all going to depend on positioning and how wide an angle the strobes cover.
Sigh ... I'm well aware of that.(sigh!...) I'm not trying to light a photo with the strobe.
If you mount them on the front do so entirely temprorarily so that if you encounter stray light problems they and their attachments are easily removed. Belly mounting ----what about ground clearance? I have a reflector for the belly of an M2P/Z, in some respects it's a great idea but it needs landing extenders fitted to the drone to clear the ground.
Very nice flying at Cathedral Rock. I was there several years ago, (pre-drone owner). Jealous! I do have some very nice still images however. (one is mounted my wall). Flying was steady, careful, and respectful of the site. Loved the ending sunset and red-hued clouds.Only if you are close to a solid surface... like the ground. Otherwise I have never seen any effect in images or video from ARC2s or ARC XLs mourned in @Aerial-Pixel mounts on legs, LG, or arms of my drones unless I was in dense fog... even at dusk... example below... check the landing.
I have been using a top mounted LED strobe for all my night flying, I find that because of the relative cover/shade that the gimbal has, so far I have had no sign of light leaking from the strobe. However you can get light from the strobe bounced back from reflective surfacesI’m about to fit a Mavic Air 2 with some Firehouse lighting, mostly to maintain VLOS. It occurs to me that a flashing strobe could show up in any photos that are taken. Is this an issue??
