For my Mavic Air 2 in order to fly a half hour before and after sunset do I need a strobe white light visible for three miles? If so, do I put it on the right front arm, thus the direction I’m flying to.
You need nav strobes: red, left front; green, right front; white, rear. These must be visible for 3 miles.
Since the FAA will accept a red rotating beacon or white stobe lights as part of the required "Anti Collision Lights" on an aircraft (night). I would think any DJI drone with all it's blinking lights would qualify but I'm certainly not the final word on that. You don't need standard position lights but for your own orientation you should know the location of the lights on your drone..you can turn off the front red lighting when using the camera and that's caused me concern a few times when I forget that's why I can't see it. I'm thinking that the white landing light is going to be very handy.
Three miles visibility is required for VFR flight in aircraft. "visual flight rules" I'm not so sure you can see all strobes at three miles.
This is going to be long ..bear with me..
It's better to scan at night. You have a blind spot directly forward. The Cones and Rods in your eyes take time for adjustment. The cones take about 10 minutes and you will be able to see about 100 times better than first entering darkness. The Rods take another 30 minutes or so and you will be able to see 100,000 times better..it only takes seconds to destroy that.
